Removing Front Rotors 2.7T
Old Mar 28, 2007 | 08:09 PM
blanthony's Avatar
Default Removing Front Rotors 2.7T
I have a 2000 2.7T and I need to replace the pads and rotors. I found a guide to replace the front pads and they were simple to take out. However the rotor was a different story. I figured it would come right off. How do I get the caliper off to get the rotor off. Any suggestions...i think I have an idea but I'm not sure. Thanks.
Old Mar 28, 2007 | 08:18 PM
dms319's Avatar
Default RE: Removing Front Rotors 2.7T
Remove item 6 ( two bolts) This will remove the caliper mounting bracket. Then you can take off the rotor
Old Mar 29, 2007 | 12:50 AM
blanthony's Avatar
thanks. looks like you attached a pic but it's not showing up. I think I know what two bolts you were talking about. will give that a try.
Old Mar 29, 2007 | 01:28 AM
jgurland's Avatar
It will be pretty clear which bolts they are. And if I remember correctly, it's a 7mm hex key.
Edit: Ooops, thought we were talking about rear rotors. My comments do not apply to front.
fourringking
Jul 18, 2012 03:27 PM
brrman
Apr 16, 2009 04:26 PM
freestyleski
Feb 21, 2008 11:24 PM
CTown
Jul 3, 2007 07:31 AM
TooSexy
Mar 8, 2007 01:02 AM
