Removing the Lower dash in 2004 A6
Old Jan 15, 2010 | 06:33 PM
frizzlefry's Avatar
Default Removing the Lower dash in 2004 A6
Hi All,
I had a Blinder M25 professionally installed and now I am upgrading to the new M27. My heads are compatable, just need to replace the CPU box, power, ground and switch. All are located behind the lower dash, just above the left foot rest. Can anyone provide instructions or a link to instructions on how to remove the lower dash so I can gain access to the blinder CPU? Pictures would be great if anyone has any.
Thanks all!! Much appreciated!
Old Jan 17, 2010 | 09:39 AM
bob martin's Avatar
Pull out the cover just above the steering wheel (pull straight back).
Remove 5 8mm bolts (2 you just uncovered, two at the bottom and one inside the fuse cover on the left side of the dash.
Remove the lower dash. You will have to pop out the VAG-COM connector and the courtesy light.
Bob
Old Jan 17, 2010 | 02:04 PM
frizzlefry's Avatar
Thanks Bob!
ard978
Sep 29, 2013 12:04 PM
theunknownprince
B7 Models
Apr 12, 2011 08:46 PM
audib5971
Mar 13, 2009 09:53 AM
Bad Justin
Sep 30, 2008 10:27 AM
reub777
Feb 1, 2007 08:41 PM
