Replace plugs, 2.7T
Old Aug 19, 2007 | 03:15 PM
tomz322's Avatar
Default Replace plugs, 2.7T
I am in the process of changing plugs on a 2.7T (A6). You need some vertical airspace to pull the coils off of the plugs. The front two plugs have turbo plumbing as a partial obstruction. I am seeking some advice on how to clear space for the two front plugs so that coils can be removed and the plugs accessed. Thanks.
Old Aug 19, 2007 | 05:49 PM
Cmoney's Avatar
Default RE: Replace plugs, 2.7T
Hey Man, go to www.audiworld.com/tech/eng.html. Go down to A6 and they have a good visual for a sparkplug swap for the 2.7. I have a 2000 2.7 and it helped me get mine. Hope it helps you. Good luck
Old Aug 19, 2007 | 07:36 PM
solo92s10's Avatar
Thats the intake tubing going to the turbos that is in your way. I just took the bolt off each side and unhooked the intake pipe and the dv valves and pulled the whole pipe out.
SF8
Sep 9, 2010 11:05 AM
fairtrade
Aug 18, 2009 03:32 PM
bottlecap
Jul 26, 2009 12:11 AM
mitao2000
Apr 4, 2009 02:12 AM
dhescheles
Jan 7, 2009 05:06 PM
