Replaced Coil Pack, spark plugs, still misfiring!
Old Apr 6, 2007 | 05:05 PM
psx2dude's Avatar
Default Replaced Coil Pack, spark plugs, still misfiring!
hi all, Vag-Com is telling me that my 2000 4.2 is misfiring in cylinder 7 i am getting these 2 trouble codes
P0307 - misfire cylinder 7
P1411 - Secondary air injection system bank flow too lean
i have changed the coil pack for cylinder 7 and changed all the spark plugs because a week ago i was just getting the p0307 error
so now i have 2 codes coming up, any ideas on what the problem might be with cylinder 7? i was thinking it could be the coil pack wire harness, but i dont want to run out and buy it before asking here first.
thanks
Old Apr 8, 2007 | 02:22 PM
SSn's Avatar
SSn
Default RE: Replaced Coil Pack, spark plugs, still misfiring!
Might be injection problem. Can you see the engine missfire, does it shake?
Also you might check your plug wires with multimeter.
Old Apr 8, 2007 | 02:39 PM
techbod's Avatar
P1411 is the most common culprit
secondary air injection (AIR) system, bank 2 - insufficient flow detected,
possible causes are intake leak, hose(s) blocked/leaking, AI valve/solenoid bad.
P0307 just means a misfire on cylinder 7 which is probably caused by the above
Old Apr 8, 2007 | 10:36 PM
psx2dude's Avatar
the car will only shake on startup for a few seconds after it has been sitting for hours like overnight. i will grab a multimeter to check the wires, thanks guys for the input
drft1
Jul 5, 2010 12:19 PM
Fusion
Apr 27, 2010 07:30 PM
jsoverson
May 27, 2009 08:37 PM
brandons34
Sep 11, 2007 11:22 AM
d_maniac
Jun 2, 2006 01:06 AM
