Replaced Hazard Relay With No Luck
Old Apr 15, 2009 | 10:38 PM
omeara7's Avatar
Default Replaced Hazard Relay With No Luck
I had the common 'turn signal random clicking noise' issue so I replaced the hazard relay with a new one and now it's worse. Now, the random clicking is almost non-stop and it’s much faster now. Any ideas what the culprit might be? I know it might be the turn signal arm but wanted to see if there are any other possibilities. Thanks.
Old Apr 16, 2009 | 12:35 AM
auditech79's Avatar
The turn signal stock is shorting out the relay, its quite common. You will need to replace the turn signal switch, then put in a new relay.
Old Apr 16, 2009 | 08:57 AM
Boston Driver's Avatar
DIY signal stalk replacement info here:
http://www.audiworld.com/tech/elec162.shtml
Old Apr 16, 2009 | 09:44 AM
omeara7's Avatar
Thanks guys! Looks like I'll be replacing the turn signal stalk...Thanks for the DYI link - that'll help A LOT. I'll let you know how it goes.
Old Jul 24, 2010 | 09:14 AM
jhedges983's Avatar
Default 2001 A6 2.7 T Not Same as Suggestion
I have read the DIY to replacing the turn signal stalk but it is different than the one shown. Got the airbag unhooked in one area but couldn't unhook the other. Finally gave up. Mine has a yellow connector, got that unhooked, then a white one, also got that unhooked. There is a stubborn black connector that I finally gave up on. Also, the plate holding the bag didn't come off with the bag. Any ideas?
Old Dec 19, 2010 | 06:24 AM
999999's Avatar
Would a bad signal switch also cause the windshield wipers to not function? Also the blower for the climate control does not work. I got a code for that when I ran the vag-com. Could the motor be good and be related to the other symptoms?
i have tried a new flasher unit, a new ignition switch and tried a new relay.
RowdyAudi19
Apr 27, 2014 08:12 AM
0956JLee
May 20, 2013 08:19 AM
catdog
Nov 8, 2009 01:13 AM
randomloginname
Apr 1, 2008 11:13 PM
modset
Feb 26, 2008 06:51 PM
