Replaced Pads/Rotor Now Brakes Locked!
I replaced my rear pads and rotors today and then I could not move the car at all. I don't know what I did wrong. I did release some brake fluid out of each caliper in order to turn in the caliper without the right tool. Bled each one just a little bit. Emergency brake adjustment makes no sense to me in the Bentley manual. Tried to adjust but between the removal of center consol AC and turning the adjustment nut...I don't get it. Both rears are locked. Front wheels turn fine. Maybe I got air in the lines? I'm at a loss.
There was no reason to remove fluid to compress your rear calipers, in order to bleed these brakes you need a vag com and a power bleeding system or damage to the anti lock system can occur.There should not be any adjustment needed to the parking brake unless it was not performing correctly. you may need to contact your local indy shop and get your calipers properly bled.
Yep, it was kind of dumb to bleed the brake. Thought that would help compress the piston with the C-clamp while turning the piston. I did get the piston in and I bled each rear a little just to make sure no air got in. What could have happened? Should I pull it apart and re-do or tow it to my mechanic? I mean the wheels won't budge.
Went to re-inspect and finally discovered a problem. The rotor was the wrong size. The width of the hub is a full 1/4 inch wider. Autoparts Warehouse send the wrong size and they look exactly the same without measuring. Pick'n up a new set manana. Should solve the main issue. I always take an old rotor in to compare but bought these online a year ago. Won't do that again!
