Replacement engine sounds WIERD
Old Sep 25, 2006 | 09:01 PM
SAMERA's Avatar
Default Replacement engine sounds WIERD
Hi everyone!
I recently purchased a Audi A6 1.8t 1999 from a friend but the engine packed up on her. I went to a local friends garage and they replaced the engine along with the clutch and timing belt kit. The car started instantly. after bringing the car home the next day i drove it to work and the wierd sound is coming from the engine. it seems as if their is a motorcycle by my car. i have no loss of engine power and everything else seems fine. no lights on the dash come up. it starts ok then 10mins later a clicking sound comes from the fanbelt area then it goes worse and worse. someone told me it maybe the alternator, someone else told me it maybe tappets.
Please help i cant afford another engine, and my friend at the garage doesnt have any idea also. by the way the engine code is APU. Please help
Love SAM
Old Sep 26, 2006 | 02:17 AM
dankhound's Avatar
Default RE: Replacement engine sounds WIERD
Remove the accesory drive belts. Then you will know if it is one of the accesorys or not. If its loud like a motorcycle youll want to check for exhaust leaks also.
Old Sep 26, 2006 | 04:39 AM
01A4T's Avatar
you have an A6 1.8T?
Old Sep 26, 2006 | 05:57 PM
SAMERA's Avatar
Hi Everyone
yes 01A4T I have a Audi A6 1.8t 1999 with an APU engine code. hope this helps you.
Love SAM
Old Sep 26, 2006 | 06:00 PM
SAMERA's Avatar
Hi dankhound
I Have been told by my local garage it is not the accessory belt nor the exhaust. He checked both of them today. Im confused I really like this car but the sound is becoming unbearable!!!!
Please help
SAM
Old Sep 27, 2006 | 01:41 AM
dankhound's Avatar
Does it come and go as the fan comes on and off. The fan motor bolts come loose sometimes. I would also check to make sure that everything replaced with the timing belt is still tight.
Old Sep 27, 2006 | 06:11 PM
SAMERA's Avatar
Hi DankHound
My local mechanic has investigated the timing belt and is visually fine. Today I noticed the sound was coming from behind the engine by the Catalyt Convertor, maybe this will help. It takes approximately 20mins for the sound to appear after a cold start. When I press the clutch down on the car the noise seems to get loader.
Many Thanks
Love Sam
Old Sep 27, 2006 | 06:22 PM
techbod's Avatar
clutch thrust bearing no point just changing that change all 3 components clutch plate/pressure plate and thrust bearing, don't get the fly wheel skimmed as its a waste of time and money ( USA skim rip off ) change the flywheel if you think its that bad and its cheaper in the long run
[IMG]local://upfiles/12092/7D8DB3F552514E6BBC7C55072EE76942.jpg[/IMG]
Old Sep 28, 2006 | 02:43 AM
dankhound's Avatar
Your not supposed to machine the dual mass flywheel anyway. But yeah thats most likly the culprit. Unless the flywheel or pressure plate was somehow left loose.
Old Sep 28, 2006 | 07:16 PM
SAMERA's Avatar
Hi peeps
Thanks for the advice. My car is going back to the garage tomorrow to get the parts replaced. ill let you know of the outcome
Many Thanks
SAM
maksinx
Jun 4, 2010 04:08 PM
motegiman07
Feb 19, 2008 02:10 PM
cantdrive55
Jan 25, 2008 05:55 PM
egyptianluver88
Nov 29, 2007 12:56 AM
michaelangelo03
Apr 8, 2006 11:58 PM
