Replacing Radiator
I actually ordered them from genuinevwaudiparts.com. I would think that hardware o-rings would be fine as long as they are the same size. I ordered them because I was already ordering the radiator and the other stuff from them. Sorry, I don't know what size they are.
I noticed that too. For some reason their website is having some issues but you can access their website by doing a google search and clicking on one of their sub pages. It will let you in.
I always had good experience with them. I think they are actually a dealer, but sells their parts at wholesale rate to the general.
The top o ring get pinched but I used a new one and it sits flush. the bottom one is out a few mm. This weekend I will see if I can get it to fit correctly. Im starting to wonder if the connection on radiator is faulty.
Still didn't get the transmission cooler lines to work yet, but I have a question on the freeze plug. I remembered to move it to the new radiator but forgot the o ring. well the issue is that I think I may have tightened it too tight now I can't get it back out. The allen wrench starts to strip the freeze plug when I try to unscrew it. Any ideas on how to remove it? Or should I just leave it in place now without the o ring?
I did fill it up with distilled water before filling with coolant just in case it leaked. The lower hose was not connected properly and a bunch of water leaked out but I got that fixed. Thanks for your advice. This project has taken me a longer then expected, but I guess that's how cars are.
I finally got the transmission cooler line to connect. It had a small lip on it from me using a screw driver to disconnect it. I used a fine sand paper to sand down the slight lip, then the upper transmission line seated. I filled up the radiator with distilled water to test it once more. The transmission fluid didn't leak, no coolant leaks from the hoses. Ran the car for a few min, there is a small leak from a hole in the new radiator. I got a replacement radiator on its way. Maybe next weekend I can get the car put back together.
