Same ol' door panel question...
Old Mar 13, 2008 | 07:30 PM
Muvinair's Avatar
Default Same ol' door panel question...
Hi all. New here. Bought a 1996 A6 Quattro last weekend. Very nice, indeed. Problem...Inside driver's door release does not open door. Have gone through the threads here regarding the removal of the inside door panel, but having no luck. The hole beneath the door pull is evident, but there is a slotted plastic piece present. The threads imply that one should be able to slide a thin tool up to the underside of the switch plate. Not so. Don't know what to do. Have tried pushing vigorously but no movement, and don't want to damage anything. Can someone please help?
Old Aug 17, 2008 | 03:27 PM
briggen's Avatar
hey man, im having the same problem.....there is no release in the hole under the door panel. its just an empty hole!
i have no idea what to do. and i dont want to rip off the panel and break it.....if i find anything ill let you know
Old Aug 17, 2008 | 03:58 PM
ryuuoh's Avatar
Old Aug 19, 2008 | 04:02 AM
NH_USA's Avatar
I believe the issue is removing the arm rest The rest is straightforward.
There are three holes on the bottom side of the armrest that contain allen head screws. These screws move clamps that hold the arm rest in place.
The door opener is Easy - just remove the screw that is undr the plactic cover and slide it towards the rear - it will come loose and all you need to do is diconnect it from the arm that goes to the release mechanism.
There are a few small screws near the edges of the pannel.
Then the bottom pops out and you move the pannel upwards to release it from the lip at the window.
I'm in China for the next few weeks so I trying to explain from memory...
audi guru
Jun 6, 2013 04:39 PM
Buttery Cracker
Dec 26, 2007 09:20 PM
Stargazer
Dec 1, 2007 11:06 AM
Buttery Cracker
Dec 12, 2006 01:59 AM
flaudi4life
Apr 4, 2005 01:15 AM
