Say I was to ignore the P0158 code...
Old Jul 1, 2010 | 12:19 PM
alex jb's Avatar
Default Say I was to ignore the P0158 code...
SO I've had the P0158 code 3 times, first two times were a few days apart between re-setting, then again this morning which is 2 months later.
If I have no intention of spending sunny weekends under my A6 replacing sensors and tracking wiring to look for faults, what is the effect of not addressing the code and just re-setting it?
Worse MPG?
Loss in performance?
Unless I get the emmisions check letter in the post, I don't think I'm going to address this until the fall when garage time is a goos use of bad weather weekends.
Old Jul 1, 2010 | 01:00 PM
NH_USA's Avatar
OH NO!!! You have high voltage from the second O2 sensor on bank 2.
Stop being lazy and fix it!
Old Jul 1, 2010 | 01:23 PM
alex jb's Avatar
Default fix it
I guess I could if I knew it was definately the O2 sensor, read lots of cases of people changing them out and the code comeing straight back (issue in the wiring?)
Lot's of parts places list them, but thought this was a dealer only sensor?
Also, is it necessary to replace both rear sensors at the saem time or even all 4?
Old Jul 1, 2010 | 01:52 PM
jhuffman's Avatar
the second set of 02 sensors is just for emissions. And no they aren't dealer only sensors.
RomanNY
Apr 24, 2010 10:42 AM
99BlackA4
Dec 29, 2008 09:10 PM
joshuo
Jul 19, 2007 09:25 PM
mlo517
May 13, 2005 05:55 AM
