Seafoam or not to seafoam
Old Sep 7, 2011 | 09:55 PM
budhani786's Avatar
Default Seafoam or not to seafoam
I was planning to use it in the crankcase and vacuum line. Has anyone tried it on the 2.7 or 2.8 a6? Lots of people say it's done wonders. Can it be bad for 2.7's turbos if i put it in the oil?
Old Sep 7, 2011 | 10:17 PM
hxgaser's Avatar
Seafoam does wonders; however, expect to develop some oil leak at the usual spots after the crankcase use. FYI, your car has a 99% chance that it will develop oil leaks. The Seafoam is only expediting the process.
Old Sep 7, 2011 | 11:14 PM
budhani786's Avatar
oh wow i just got those leaks fixed 1000 miles ago. Lol. I want to pour it in the 2.7 but some people say that it's not a good idea since that goes thru the turbo. I thought it would be good to clean the oil lines for it.
Old Sep 8, 2011 | 09:42 AM
02A6Beau's Avatar
I did the seafoam crankcase treatment on my 2.7T about a year and half ago. I agree with hxgaser, it definitely hastened the onset/rate of my valve cover gasket leak. I really didn't notice any effect on anything else (but it obviously had to do something, right?). If you are going to do it I think the key is get the seafoam in there, drive for a reasonable distance (like 100+/- miles) and then change the oil. It is my understanding that you don't want it sitting around for too long after adding it.
-not an expert, just an enthusiast
Old Sep 8, 2011 | 10:54 AM
budhani786's Avatar
how about in the vacuum? if i suck it thru there? what are the pros and cons of that? would it foul the oxygen sensors?
Old Sep 8, 2011 | 12:38 PM
hxgaser's Avatar
If you fixed all the oil leaks recently, then you should be okay to use seafoam. The reason that the oil leaks develop is that old residue that dried/stuck on the seals become loosened by seafoam. Then the leaks develop. If you have fresh gaskets and seals, then you should be okay.
Seafoam will have no issues running through the turbos.
Old Sep 8, 2011 | 12:39 PM
hxgaser's Avatar
Oh yeah, running seafoam through vacuum will not affect your o2 sensors. Just be sure to do it in a well ventilated area, because it will smoke out the entire neighborhood.
Old Sep 8, 2011 | 08:07 PM
Kite09's Avatar
Where is the vacuum line on a 2.7? I wanted to seafoam that but have no clue where to put it. Also, is it safe to use in the gas tank to clean fuel lines, or will it cause leaks there too?
Old Sep 9, 2011 | 08:45 AM
bob martin's Avatar
Safe to use in the fuel system, but plan on new spark plugs soon afterward. There are several places to tap into the intake vacuum. There is a vacuum line that runs off the engine on the driver's side front and over to the fender well. There is a "quick" disconnect on the fender well so this would seem to be a good place to tap. I need to do this myself but have been waiting until I am ready for new plugs and an oil change so let me know how it goes.
Bob
Old Sep 9, 2011 | 01:53 PM
Kite09's Avatar
Ugh, then I guess not in the fuel system either. I was going to do this before I got my tune up and stuff done, but forgot. New plugs and evrything. So I guess I don't want to foul those up. Vacuum line only it is then.
