AudiForums.com
-   Audi A6 (https://www.audiforums.com/forum/audi-a6-9/)
-   -   servicing message???? (https://www.audiforums.com/forum/audi-a6-9/servicing-message-34130/)
bigblokey0 Jun 14, 2006 06:13 PM
ive got a servicing message that comes up on my dashboard saying "service needed in 800 miles"how do i get rid of it ?
SouthboroAudiGuy Jun 14, 2006 06:46 PM
RE: servicing message????
If you've still got your manual, the instructions for this are in there.
bigblokey0 Jun 14, 2006 10:04 PM
i have got the manual cheers ill have a look tomoz thanks
aznknites Jun 16, 2006 08:22 PM
well id ont have a manual can someone help me???
cary12 Jun 16, 2006 11:18 PM
ORIGINAL: aznknites
I'm with you as well. I had mine serviced and it still says "service" when I turn my car on. I'm not taking it back in to have them turn it off. Gotta be a way to do it?
SouthboroAudiGuy Jun 17, 2006 12:13 AM
1. Insert your key into the ignition.
2. Push in the odometer reset button, hold it in, and turn the key to the first click.
3. The display should read either "oil" or "service" if it does not, repeat steps #1 and #2.
4. To reset, pull out your instrument light dimmer button at the bottom of the tachometer.
5. Turn the ignition to the off position. When the ignition is turned back on, the display should be back to the trip odometer.
cary12 Jun 17, 2006 03:30 AM
Didn't work with my car....
bigblokey0 Jun 17, 2006 05:42 AM
this is what it says in the manual
switch of ignition
press button 2 (left hand side) and hold while switching on the ignition.the display should now read SERVICE
press and hold button 1 (right hand side) until the word SERVICE is cleared from the display
try that it should work i guess
SouthboroAudiGuy Jun 17, 2006 09:59 AM
There were two sets of instructions I found when searching. BigBlokey has kindly provided the other set. Works on later models.
cary12 Jun 17, 2006 02:03 PM
Ok. Let me make sure I'm doing this right. I put the key in the ignition. I hold down the left button and turn the key to the first click. Now my message screen reads that dumb a@# message about depressing the break and putting into gear. There is no "SERVICE" message. I only get that message when I turn the car on and put it in gear. Am I doing something wrong?
