servicing message????
Old Jun 14, 2006 | 06:13 PM
bigblokey0's Avatar
Default servicing message????
ive got a servicing message that comes up on my dashboard saying "service needed in 800 miles"how do i get rid of it ?
Old Jun 14, 2006 | 06:46 PM
SouthboroAudiGuy's Avatar
Default RE: servicing message????
If you've still got your manual, the instructions for this are in there.
Old Jun 14, 2006 | 10:04 PM
bigblokey0's Avatar
i have got the manual cheers ill have a look tomoz thanks
Old Jun 16, 2006 | 08:22 PM
aznknites's Avatar
well id ont have a manual can someone help me???
Old Jun 16, 2006 | 11:18 PM
cary12's Avatar
ORIGINAL: aznknites
I'm with you as well. I had mine serviced and it still says "service" when I turn my car on. I'm not taking it back in to have them turn it off. Gotta be a way to do it?
Old Jun 17, 2006 | 12:13 AM
1. Insert your key into the ignition.
2. Push in the odometer reset button, hold it in, and turn the key to the first click.
3. The display should read either "oil" or "service" if it does not, repeat steps #1 and #2.
4. To reset, pull out your instrument light dimmer button at the bottom of the tachometer.
5. Turn the ignition to the off position. When the ignition is turned back on, the display should be back to the trip odometer.
Old Jun 17, 2006 | 03:30 AM
cary12's Avatar
Didn't work with my car....
Old Jun 17, 2006 | 05:42 AM
bigblokey0's Avatar
this is what it says in the manual
switch of ignition
press button 2 (left hand side) and hold while switching on the ignition.the display should now read SERVICE
press and hold button 1 (right hand side) until the word SERVICE is cleared from the display
try that it should work i guess
Old Jun 17, 2006 | 09:59 AM
There were two sets of instructions I found when searching. BigBlokey has kindly provided the other set. Works on later models.
Old Jun 17, 2006 | 02:03 PM
cary12's Avatar
Ok. Let me make sure I'm doing this right. I put the key in the ignition. I hold down the left button and turn the key to the first click. Now my message screen reads that dumb a@# message about depressing the break and putting into gear. There is no "SERVICE" message. I only get that message when I turn the car on and put it in gear. Am I doing something wrong?
