shaking on highway with new rims
Old Sep 5, 2006 | 03:54 PM
peppyA642's Avatar
Default RE: shaking on highway with new rims
Make sure the lug nut torque is to spec.
Old Sep 6, 2006 | 01:42 AM
dankhound's Avatar
What were your roadfore readings. The machine wont recognize a wheel/tire assembly in the 15-25 pound range as bad but those numbers can be significant enough to cause a vibration.
Old Sep 6, 2006 | 02:02 AM
RAYCABRERA's Avatar
LUG NUT TORQUE? SHOULD I HAND TIGHTEN THE LUG NUTS?
Old Sep 8, 2006 | 02:31 AM
gpz's Avatar
gpz
A slightly out of round wheel could balance out perfectly, yet you would notice it vibrating at highway speeds. I had this issue with an OEM wheel that had hit a pothole.
What type of wheels EXACTLY are you running? Did you determine if they are hubcenctric or not? If you mount up a non-hubcentric wheel without an adapter spacer, then the wheel will vibrate and shake at speed (act like it is out of round) due to it not being perfectly centered on the hub. This is also a dangerous situation, as the sheer stress is being applied to the lug bolts, and not to the wheel hub like it should be.
Old Sep 8, 2006 | 12:19 PM
RAYCABRERA's Avatar
I THINK THEY ARE OEM WHEELS ALSO. AND IM NOT SURE HOW TO TELL IF THEY ARE HUBCENTRIC. HELP!
Old Sep 8, 2006 | 12:20 PM
RAYCABRERA's Avatar
sorry for the caps. they are o.e. wheels.
Old Sep 8, 2006 | 02:02 PM
beefski's Avatar
Why not try rotating the rims to different axels. Follow the manufacturers recomended rotation pattern then try a highway blast.
Old Sep 8, 2006 | 02:17 PM
  #18
techbod's Avatar
they are called spigot rings and required to center the wheel, they fit in the rear of the alloy and make the wheels fit snug on the hub
[IMG]local://upfiles/12092/82F788E3CC154848898DB1B620DFC6F4.jpg[/IMG]
Old Sep 10, 2006 | 04:40 AM
  #19
gpz's Avatar
gpz
OEM wheels as in they have an Audi four ring stamp on the inside near the hub, or OE Wheels as in the eBay retailer that sells knock-off wheels in great quantities?
ORIGINAL: RAYCABRERA
Old Sep 10, 2006 | 09:52 PM
  #20
RAYCABRERA's Avatar
right. oe wheels from ebay. did i make a mistake?
