side door trim 4.2L
Old Nov 6, 2009 | 03:31 PM
WoodShoe's Avatar
Default side door trim 4.2L
Anyone know how to take off the lower door trim on a c4 4.2L? The two screws that are visible are rusting and once they are off its still on there solid. Do i have to remove the door panel?
Old Nov 6, 2009 | 06:22 PM
jchaffee1's Avatar
i think you have to slide it sideways then pull
Old Nov 6, 2009 | 08:21 PM
chefro's Avatar
JC is right, the trims are designed to be slid and pulled, but their metal clips rust over time inside the door card.
You neeed somehow to try to gently pry after you slide them (toward the rear of the car), but with something that won't scratch or damage your paint.
I wanted to paint mine and I could not remove them. I gave up and painted them on the car, anyway. You can also remove the door card and push'em from inside, but that would be a bunch of work
Old Nov 7, 2009 | 06:07 AM
WoodShoe's Avatar
Thanks guys. Sounds like its going to be a PITA. The reason I want to remove them is because something under them is rusting. Prolly the clips as you mentioned. And it leaks rust onto the paint. Mr. Clean eraser takes the rust right out and you cant tell its there, but it doesnt solve the problem. Ill try to soak it in penetrating lube for a while before I attempt it.
Old Nov 7, 2009 | 10:06 AM
kingofnyc22's Avatar
Member
Slide towards the rear of the car and it will come right off.
Oz_racing
Jul 19, 2009 12:42 AM
nismonewf
Nov 27, 2008 08:43 PM
Airmen
Mar 31, 2007 07:51 PM
cmk87
Dec 28, 2006 04:15 PM
98A4V6
Dec 10, 2005 02:21 AM
