Side Light / Daytime Running Light, Left-Side Fault
54 reg A6 with the error popping up on my Driver Information System
"Side Light / Daytime Running Light, Left-Side"
I can't find any bulbs not working, all seem ok.
Any ideas/Anyone else had this issue ?
Google only brings up some Russian Audi Site :-( There is nothing mentioned in the manual either.
Thanks
Thanks
Sorry you didn't find any answers or help in nearly two months.
Although it usually helps to give more details about your car (I have no idea what "54 reg A6" suppose to mean), this one obviously has something to do with a sensor or a non-recognition of the proper amperage/voltage in either the side marker or the DRL circuit.
Depending on the year of your car, you need to find out IF you have sensor/s (and its/their location) responsible for recognizing the proper voltage or the proper functioning of the bulbs.
If your bulbs are ok, then you need to inspect the sockets, wires, etc. It would be hard for someone to give you the perfect electrical diagnosis over the Internet.
good luck, bud.
good luck, bud.
Hi
I have the same alarm for the right side
Again all bulbs are fine and working
How did you resolve your issue
Mine is A6 Tdi 2.0 55reg
Thanks
Thanks
mannyg_87
Feb 23, 2015 03:08 PM
crazybk187
Aug 5, 2013 04:29 PM
