some help with Audi A6 quattro 1999 parts
i bought my audi a month ago, I need to replace some parts but I am trying to spend the less money I can. The parts I need are: the switch for the side mirrors, a new rear mirror, also the sun roof is not opening it only goes up and down. At the dealer they said that a part of the frame got broken (I have the part) so the whole frame must be changed but it is for about 500 dollars! The rear windows lock/unblock switch is in block position and it only goes unblock when I hold it down.
My cruise control is not working at all, I checked the fuses and I don't have it but also the little metal parts that are supposed to hold the fuses in the fuses board are not there so when I tried to put a fuse it didn't worked.
Also I can't make the seats memory to work, does anyone know about this?
I have tried too to find the manuals but I had no luck on this.
I will appreciate if someone can help me.
Thanks ya'll!
Thanks ya'll!
Cruise control: if fuses aren't your problem, which it sounds like it might be, here is a one solution: http://forums.audiworld.com/showthread.php?t=1728645 (notice my posts in there, so ask if you have more questions) please note that this only MAY be the problem, other sources could be your brake switch or the actual stalk on the steering column (both less likely). If your not electronically inclined (haven't soldered), than you should probably find someone who is. This worked for me like a charm, so I think there is a high chance that lots of vehicles have this problem, especially if you live in a very wide range of climates (it's caused by a lot of hot/cold cycles over the past 10 years).
a.walker727
09-25-2011 08:20 PM
99A4NOW
05-31-2011 05:54 AM
BarnaZ-A4
21
08-04-2010 08:58 PM
joaquin504
05-08-2009 07:24 PM
