Spark Plugs for A6 ?
Old Jan 3, 2009 | 12:12 AM
chefro's Avatar
Question Spark Plugs for A6 ?
Before getting my Repair Manual I guess I can keep begging for answers.
Is the two-electrode Bosch (7402 I believe I've seen somewhere) the OEM spark plug?
Do you guys buy iridium, platinum, or normal ones (NGK/Champion, etc)?
Thanks much in advance.
Old Jan 3, 2009 | 01:53 AM
afstud6900's Avatar
Banned
that is what i was told... in my 99 a6 2.8Q i have the bosch with four electrodes and they are better. and last alot longer, they seem to be better on performance and fuel economy as well. but just a little bit ive noticed an improvment.
Old Jan 3, 2009 | 09:30 AM
Coors's Avatar
http://www.ecstuning.com
look for NGK - Spark Plugs (#PFR6Q) - Set Of 6 Plugs $72.85
ES#576
You should not experience gains from one plug to another. Effieciency yes!
I should clarify, that if your current plugs are fouled or have a substantial amount of miles on them, then yes you would feel a gain in power and performance.
A common misconception is that changing spark plugs will result in a large power increase. In most cases, removing even seriously worn out spark plugs will only result in very modest power gains, typically about 1-2% of total engine output. This could be even less for computer-controlled vehicles, primarily because most newer vehicles have more powerful ignition systems and the vehicle's computer can make adjustments so that vehicle operation seems smoother and more seamless.
Many people think that simply supplying more spark to the firing tip can and will combust more fuel. What they don't understand is that most newer cars' engines are so efficient that they are already burning all of the available fuel. Simply adding more spark voltage can't burn more fuel because there is no more fuel to burn.
When a stock or near-stock engine is given a fresh set of spark plugs, peak efficiency is restored. The power gains that come from this restored state of tune are usually minimal. Any company that tells you that their spark plug will provide significant gains in power in a stock or near-stock engine is making blanket statements that may not be supportable.
Source is from NGK's website
Old Jan 3, 2009 | 02:04 PM
chefro's Avatar
Thanks for the opinions and link, guys.
Well, the most expensive ones at AutoZone are
- NGK Iridum (Ix) ---- $ 6.99/piece
- Bosch Iridium/Fusion.. $7.99/piece.
Is there anything special about the NGK plugs sold by ecstunning?
Old Jan 3, 2009 | 05:20 PM
smtcapecod's Avatar
sparkplugs.com has a little write-up that explains the characteristics of different types of plugs, and then a note on each plug that is offered for a particular application.
Old Jan 3, 2009 | 07:57 PM
chefro's Avatar
Thanks, smtcapecod.
I was hoping someone would really confirm/infirm what's the OEM spark plug, but I guess the sparkplug.com might give me some clue...
As a matter of fact, I see there that the NGK PFR6Q ecstuning.com sells is a double platinum plug.
At least I got something out of it.
Thanks again.
Old Jan 5, 2009 | 01:51 PM
ningshen's Avatar
Sorry to hijack the thread. I have the same car (2005 A6 3.2Q). My local dealer quoted me ~$400 to replace the entire set (6) of spark plugs. Is this something I can do myself, or it is really a jot for the professionals.
Thanks in advance.
Old Jan 5, 2009 | 02:13 PM
chefro's Avatar
Shen,
replacing the spark plugs is something you can do on your own. If you have the spark plugs ready, it shouldn't take you more than 5 minutes per plug to replace it. 30 minutes for the whole thing should be more than enough time, unless you're picky and start analyzing the old plugs, cleaning the eventual debris around the holes, etc.
Anyway, it is as easy as unpluging the wire, unscrewing the old plug, screwing back the new plug, reconnecting the wire.
I understand that the economy is bad and the dealers mostly make money nowadays through the service department, but you would have to shoot me and still I wouldn't pay $ 400 to a dealer to replace my spark plugs.
Moreover, changing the spark plugs on an Audi is one of the easiest things to do, since they all are exposed, easy to reach to unlike other cars.
Old Jan 5, 2009 | 02:33 PM
ningshen's Avatar
Thumbs up Thank you!
Shen,
Thank you. $400 is just outrageous. With your information, I will certainly give it a shot before let the dealer make that quick $400 bucks.
Old Jan 5, 2009 | 02:44 PM
oc_audica's Avatar
NGK Iridium IX - Part# BKR6IEX
say no to platinum 4s.
