speedometer replacement
Old Aug 25, 2008 | 09:11 PM
millenia's Avatar
Default speedometer replacement
i need to replace speedometer because the info display screen is bad, now my question is can i just buy a new one?? and will it work fine and show everything same way my old one did ??? wondering about mielege also
Old Aug 25, 2008 | 10:10 PM
nm3210's Avatar
Well first off, the bad info screen is something the plagues basically all Audi's - i'd say 2003 or older - and even the VWs with the same display system. It is basically impossible to fix and so the option becomes to either live with it or deal with the dealer.
The problem with the dealer is they have to replace the whole cluster which is around $800 the last i heard. The way the clusters work is that if they have less than 100 miles or something like that they can be rolled forward by the dealer (or i suppose Vag-Com?) ONE time and ONE time only. Some people have bought clusters off of ebay in hopes that their screens are better than the one they're replacing, i have to assume that some of them are bad just the same - also the problem with that is the mileage. Mileage is stored in the cluster as far as i know so you'd be stuck with that persons mileage reading.
edit: Here's a pretty good resource for the bad info screens (basically concludes that it's impossible to fix): http://www.modifieda4.com/web/misc/trip-display.html
Old Aug 26, 2008 | 12:30 PM
Rhino85's Avatar
SoCal Crew Member
Just had it done. $800 before labor, and the dealer must do it because they need to program it to your key. I know they weren't dicking me around on that part becuase they asked if I had any other keys so they coud add it to the cluster.
Old Aug 26, 2008 | 05:13 PM
millenia's Avatar
Well i'm gonna bring it to the dealer and have it done. My father is a dealership so maybe i ll get couple bucks of under his account, but after they do it??? Does everything look good and miles are correct???
audiavant04
Mar 27, 2015 08:34 AM
ericcota2003
Sep 4, 2013 03:01 AM
dombombBMX
Dec 1, 2007 11:28 PM
aberfitch82
Nov 29, 2007 10:59 AM
neur0tic
Apr 21, 2007 01:37 PM
