Stock boost
Old Apr 13, 2008 | 05:36 PM
WeezyTT's Avatar
Default Stock boost
how many pounds of boost does the 2.7t put out stock?
Old Apr 13, 2008 | 05:53 PM
madrussian's Avatar
Default RE: Stock boost
X2 same here, and how many pounds after apr chip, giac chip?
Old Apr 13, 2008 | 06:06 PM
trapped's Avatar
I know that the chip produces about 1.0 BAR or about 14.5 PSI and I think stock is around 7 or so. I am certin about the chip, but not about stock.
Old Apr 13, 2008 | 06:13 PM
Retard Riot 686's Avatar
ORIGINAL: trapped
that stock sounds about right i believe
Old Apr 13, 2008 | 06:26 PM
madrussian's Avatar
Do all or those chips produse same amount of boost? And what is the most efficient range for k03 as far as power but without hurting turboes or motor?
Old Apr 13, 2008 | 07:07 PM
trapped's Avatar
I have seen people running around with 20+ psi and no problems. Obviously more pressure = greater risk of blowing a turbo.You CAN operatre at 20+, but 14.5 is a good level to boost at.
Old Apr 14, 2008 | 12:48 AM
formulagigi's Avatar
20 is a lot for KO3's and reliability. Sure it'll work but how long...
APR is indeed 1 bar. I think GIAC is 1.2 bar... is that 17 PSI? I would not go higher on KO3s, actually I don't run the GIAC chip or VATS just b/c I don't want more risk on my turbos.
Old Apr 14, 2008 | 12:51 AM
trapped's Avatar
1.2 bar is 17.4 psi, come on Gigi how do you not know that... Just kidding I'm taking a physics class and we always have to convert units and Psi-Bar is what we did in january!
Old Apr 14, 2008 | 01:45 AM
Hey I was close with my estimate at 17 lbs What's .4 lbs of boost among firends !
Old Apr 14, 2008 | 01:48 AM
trapped's Avatar
haha, very true I guess I'll let you slide .
