Struts
Old Mar 30, 2008 | 08:05 PM
RIA6's Avatar
Default Struts
Anyone replace their struts recently? Im trying to figure out what struts to get.
Old Apr 1, 2008 | 12:28 PM
RIA6's Avatar
Default RE: Struts
bump
Old Apr 1, 2008 | 01:01 PM
Joeski's Avatar
Default RE: Struts
Give us some more info RIA6. What type of suspension do you have? How many miles on the car?
OOOO
Old Apr 1, 2008 | 02:39 PM
RIA6's Avatar
Default RE: Struts
2003 3.0Quattro,Sport suspension. 95K on the car.
Old Apr 1, 2008 | 02:54 PM
Joeski's Avatar
Default RE: Struts
Well,
First off, I would not just replace your front struts, I would replace everything, meaning your front struts, strut bearings,rear shocks and your springs. If you want to replace with OEM, you will just need your VIN number to get the appropriate shocks and struts and bearings. I don't know if all 3.0 A6's came with a "sports" suspension. If they did not and you replace your springs (recommended), you will most likely need to give the dealer or whomever you purchase the springs from, a "paint code" that is marked on the spring. It is usually 3 different paint marks on the coil of the spring.It will signify the spring rate.
If you want aftermarket, you should only need the year, make, model, engine size, front trac or Quattro, auto or manual trans.
This is just what I experienced when I worked in the industry, I am not sure if anything has changed.
OOOO
Old Apr 1, 2008 | 10:34 PM
formulagigi's Avatar
Default RE: Struts
I started with the OEM sport suspension: Boring, lots of dive and roll, took turns pretty wide... but comfortable
then had H&R springs on stock shocks: looked nice, lower center of gravity so improved handling but bouncing and the springs ruined the shocks
next I added Koni Yellow shocks, which made the car handle even better, eliminated the bounced, lowered the car even more but it made the ride very rough! The car was very low, too low IMO. Not enough travel.
Next I switched to the Koni FSD/Eibach Pro Kit combo, which I run currently on my 2.7T. Retains most of the stock comfort, car sits pretty low and handlig is improved over stock.
I also had added the Sport sways and that made a big difference too.
Old Apr 1, 2008 | 10:48 PM
trapped's Avatar
Default RE: Struts
Gigi how much does the car roll with the H&R's and Yellows without the Sways? Did you ever have the suspension without the sways?
Old Apr 1, 2008 | 11:04 PM
Default RE: Struts
I installed the sways after the H&Rs and before the Koni Yellows.
The sways made a HUGE difference in cornering/roll, it is much more direct in turns
Old Apr 2, 2008 | 12:27 AM
trapped's Avatar
Default RE: Struts
I have heard about the benifits from everyone, but I might wait and get the sways after the car is lowered and what not. I don't think Ill be driving much after I lower the car. That is when I move to CHICAGO and the car stays in STL...
livinglegend2100
Jun 13, 2012 07:57 PM
audinoob27
Apr 6, 2012 11:15 PM
blong497
Aug 15, 2011 10:35 PM
jackason22
Feb 22, 2008 06:47 PM
jkucz28
Apr 1, 2007 04:13 AM
