suspension
Old Jul 11, 2009 | 09:17 PM
Figgy1682's Avatar
Default suspension
ok i finally got my rims on and they look nice but i got the 4x4 look going on. now i know that theres a few companys that make springs and coilovers but im focusing on springs. i love the factory ride quality of my a6 but i need to lower it. is there any one running springs with out lowered shocks/struts that still have good ride quality. i been told to go with eibach but i remember them on a honda i had and i ditched them cause they were to bouncey. i only want to go a inch or what ever it takes to fill the wheel well up a little bit. thank in advance.
Old Jul 13, 2009 | 09:07 PM
Figgy1682's Avatar
anybody?
Old Jul 13, 2009 | 10:06 PM
formulagigi's Avatar
Hey
first of, how about some pics!
for a one inch drop, look for sport springs, Eibach will go about 1.2-1.4" but I would just not do springs only especially on a 4000lbs car like ours. It'll ruin your shocks faster and give you a bouncier ride. Your shocks are not made to run with lowering stiffer springs.
I did it anf just ended up spending, no wasting money on labor a second time to add shocks, so save yourself time and $ long term, do both and you'll enjoy abetter more compliant ride IMO.
Eibach are definitely not as low and their spring rate not as aggressive as the H&R sports.
So get Eibachs with some Billstein or Koni shocks.
Old Jul 13, 2009 | 10:17 PM
Figgy1682's Avatar
thank you i appreciate the response. i dont know how to post the picks but i could email them to you if you can post them.
Old Jul 14, 2009 | 12:34 PM
hxgaser's Avatar
Listen to gigi and invest in a set of good springs and shocks. The reason that your honda was bouncy probably was because of the fact that the stock shocks were not capable of modulating higher rate springs. With that said, I have heard good things about Eibach and Koni FSD combos. I am personally considering this set up. Based on my research, FSD is the most forgiving out of Koni Yellows and Bilstein HDs. Also Eibach is less stiffer than H&R.
But once again, it all depends on your driving style. My consideration is based on having a little fun around the corner without sacrificing too much of the ride quality.
Old Jul 14, 2009 | 12:47 PM
Hxgaser
I actually have that set up now, FSD/Eibach
I ahve had
1- Stock Sport suspension
2- Stock Shock/H&R Sport (Bouncy, bottomed out, just not right and the shocks suffer quickly)
3- Koni Yellows/H&R Sport: Real low and hard, less bouncy but harsher ride, handled better on smooth surfaces, not so well on rough/uneven pavement. Looked good but rode too harsh and wifey/kids comnplained all the time. sold the setup to a fellow Audizine member who did not mind. it is all about your expectations/goals/needs...
4- Curent: FSD/Eibach springs: much more compliant ride, not quite as low, but low enough (maybe .3" higher). smoother other bumps, leans more in turn but flattens/becomes harder in hard long sweepers. FSD is progressive. It rides closer to stock set up in quality while being lower for looks and center of gravity and improving handling some.
BIsstein would be in between Yellows and FSD
I would rate from softer to harder or higher to lower:
Sport OEM/ FSD/Billstein/Yellows (Shocks)
Eibach/H&R Soprt/H&R Race (springs)
Most people dont need coiloevrs on teir A6, waste of $$ in my opinion unless you'll track the car or get into aggresssive week-end driving
Just my opinion
Old Jul 14, 2009 | 03:39 PM
Figgy1682's Avatar
not going for race just a better look with a little better handling
Old Jul 14, 2009 | 08:54 PM
then go with FSD and eibachif you're on a budget find used sport shocks and hget eibachs
luxuryimports1
Jun 23, 2009 11:11 AM
ggoodling
Nov 11, 2007 04:34 PM
i_baked_cookies
Apr 25, 2007 02:52 AM
