Suspension work
I'm just going to vent out a little bit because I have been having way more trouble with the control arms than I should be. After a terrible tirade with the uppers, a sheared pinch bolt, and alignment issues I eventually got the uppers worked out. Now the lowers, I managed to complete one side but not until BOTH of the security wheel studs cracked. I had a ball joint separator break in my face trying to do the front lower. Ok fine, I get a new front end kit and finish one side with the WHEEL ON!!! I can't get the other wheel off because the other stud cracked then too. I get under the car and the bolt attached to the ball joint on the rear lower bent instead of popping out and now I can't even get the lower arm back into the bracket to take it somewhere. FML
Is it just me or is something seriously wrong here???
