This thing is killing me!
Old Aug 1, 2012 | 01:32 PM
andyandjohn's Avatar
Default This thing is killing me!
After numerous little things going wrong I think I finally got the A6 sqaured away than I get code P0733 (gear 3 incorrect ratio)! What in the world does that mean? Hopefully a transmission service will be the fix. I appreciate any advise.
Old Aug 1, 2012 | 07:21 PM
Kevin's Avatar
Year, engine, transmission?
Old Aug 2, 2012 | 02:10 PM
Jeffla's Avatar
Where in MN are you? Generally, an incorrect gear ratio means the transmission is slipping in that gear.
Old Aug 2, 2012 | 04:42 PM
budhani786's Avatar
I have a feeling it's the 4.2 as these are notorious to throw this code.
Old Aug 2, 2012 | 06:01 PM
It's a 1997 A6 Quattro 2.8L, automatic. Shifts fine through the ranges but if I leave it in drive it seems to shift harder through the gears. Is it as simple as a trans/service or could I have bigger problems?
Old Aug 2, 2012 | 06:03 PM
Cannon Falls area.
Old Aug 4, 2012 | 09:54 AM
CRF Rider 57's Avatar
This is what I found for code P0733 - not sure if relates to your issue.
1997 A6 Quattro 2.8
Customer Concern:
Transmission goes into fail safe mode and won't shift. DTC P0733 - 3rd gear ratio error. Transmission fluid level checked ok, fluid looks ok.
Average Reported Mileage:
Tests/Procedures:
1. Check at the Transmission Control Module (TCM) for damage to connector or water damage to connector or wiring. Check fuses and circuit breakers by powertrain control module on passenger side floor.
2. Using a fully functional Audi compatible scan tool, clear DTCs in TCM and access measured value block 005 and observe the solenoid activation while driving the vehicle. Fields 1, 2, and 3 on the display should show solenoids 1, 2 and 3 and the 4th field should show the engaged gear. Check for transmission slippage while on road test. If the solenoids are continuously activated in the different gears, and DTC resets or transmission goes into limp-home mode again, the fault may be internal in the transmission.
Tech Tips:
Tech failed to perform an adequate inspection of the trans. fluid. There are several testers which can test ATF for contamination, which would have revealed the problem without having to disassemble transmission.
Old Aug 6, 2012 | 03:32 PM
That's good stuff, thank you!
1997 A6 Quattro 2.8
Customer Concern:
Tests/Procedures:
Tech Tips:
Old Oct 17, 2012 | 03:27 PM
Brick Tamland's Avatar
Did you ever get the Tranny fixed? Have the same year and engine and its throwing the same code. What did you have done to the car?
Old Oct 18, 2012 | 09:00 AM
Brick it's funny you ask because I just took the car to an Audi shop to figure it out. The car was shifting fine but still a little rough on the start so I left it with Bard at Derrick's Auto to fix a vacuum leak and check out this issue. I'll let you know.
John
cbcarpenter
Aug 1, 2013 05:07 PM
wyze
Apr 4, 2013 11:24 AM
vanessap
Dec 7, 2012 12:30 AM
PandaXpress
Dec 10, 2006 08:07 AM
