Timing belt change problem
Old Jun 21, 2015 | 11:07 AM
knole68's Avatar
Default Timing belt change problem
I am trying to replace my timing belt and water pump but have run into a MAJOR problem trying to remove the fan pulley assembly. One of the 6mm hex bolts appears to be stripped and I need it to come out in order to remove the assembly. Any suggestions on what is best way to remove this bolt? Thanks in advance for any help.
Old Jun 21, 2015 | 12:18 PM
ninetynineA6Q's Avatar
I've stripped that same bolt and used a tapered spiral screw extractor to get it out. Depending on how stripped it is, you may have to drill a little to get the extractor to bite, but it worked for me. Just tap (not pound) it into the head of the bolt with a hammer and then use a 12-point socket to see if you can turn it. Good luck.
Old Jun 21, 2015 | 08:24 PM
knole68's Avatar
Ok I will give this a try. Any idea what type/size bolts I need to get to replace? I live over 100 miles from the nearest Audi dealer but if I could get the sizes of those 4 bolts that hold that it would help. Thanks again
G3ML1NGZ
Nov 22, 2012 09:33 PM
chris
Apr 22, 2009 11:44 AM
ram
Feb 26, 2006 06:21 AM
Silver98A4
Sep 19, 2005 02:20 PM
S_R_N83
Jun 17, 2005 04:33 PM
