transmission bearing noise 1999 A6
Old Feb 5, 2008 | 10:15 AM
hslapp@aol.com's Avatar
Default transmission bearing noise 1999 A6
I have a bearing noise in the standard 6 speed transmission. My mechanic said we could continue to drive the car (80k miles) but recommends a new transmission ($$). Is this a common problem and is it safe to drive or what is the failure mode if the bearing is making noise? Have had the wheel bearings checked and are sure the noise is from the transmission. Hear the noise increase pitch as the car speeds up and the noise is there when the car is in or out of gear or the clutch is depressed at speed.
Old Oct 18, 2012 | 10:21 PM
philipkoh's Avatar
I also havbe a noise have you fixed yours and if not did it give you any trouble
crypiter
Jul 1, 2014 11:57 PM
kaotiklivin
Jul 3, 2011 06:41 PM
Mad Cow
Nov 12, 2010 10:55 AM
rchachi
Mar 25, 2010 11:15 AM
mlamson
Apr 26, 2009 04:30 PM
