transmission fluid change
hello,
i have a 1998 Audi A6 non-quattro with the 2.8L 30V engine... im planning to do a transmission oil change.. im planning on doing it myself. does one typically change the gaskets and filter at the same time or just new fluid... can someone point me to the right direction.. guide? also where can i buy it online wise, the best price and good quality..
thanks
thanks
i think this should be the kit i'm looking for, correct me if im wrong...
http://www.blauparts.com/proddetail.asp?prod=F2A1007-B
i think im just going to the change the liquid part. not buying the kit.. after i drain the old fluid, how much liters of the new stuff do i need?? they have these 1-Liter bottles http://www.germanautoparts.com/chemi...20oils/VW-Audi so will these be good? because i heard somewhere audis require special transmission fluid made for them.. so are those good. how many liters
The kit from blauparts comes with a hand pump for getting the ATF into the fill hole. You have to remove and clean the pan and replace the filter. If you don't follow the Bentley instructions for checking the ATF fluid level, you could ruin your transmission. VAG-COM is used to check the ATF temperature (www.ross-tech.com). Audi transmissions don't have a dip stick and they are expensive to service and repair.
i have a 98 a6 as well and it took 5 liters
