turbo problems
hey i sent you a reply on one of your other threads about you looking for turbos. i have a 2000 a6 2.7t one of my turbos went out oast week like the other guy said lots of smoke outta the pipes but only when i floor it and drives very rough when boosting. just a heads up if yours does this, also you need to pull the motor to replace the turbos my cars in the shop now gettin replaced
Sorry to bring a topic from the dead, but here is a update one what happen.
Right side turbo was blown. ended up replacing both Turbos and oil lines plus while It was being worked on I got my T-Belt done also along with Aux water pump. The car is broken in and pulls hard now and is doing fine.
Problem of this whole thing was Right side Turbo oil line seized up
Value is in the eye of the owner. My A8 is eight years old with 185k miles, but is in excellent condition. I figure my cost of a similar "fun" car would set me back $25-30k (2-3 year old S4 or maybe even a little older RS4). So plopping $1200 into a TB job next week is just high maintenance. Brakes and rotors all around just set me back $1000 last month (but the last set lasted 75k). And if the turbos eventually go, then I figure $6-8k for K04s, injectors, piggie pipes and I have ~400hp; vs $3-4k just to replace the stock K03s. The only open question is do I need to upgrade intercoolers and should I pull the heads and rebuild valves, replace gaskets, etc to handle the additional power?
The cost for replacing both turbos, timing belt, and aux water pump was about 6000.
#19
Turbo problems
My 2001 A6 2.7t was just diagnosed at 130k mi as needing 2 new turbos. Dealer estimate is $4800. Is it work repairing or would I be better off selling for parts and finding another one?
I replaced the timing belt and both water pumps a few months ago. The car runs fine otherwise.
