Turn signal flasher probem
Old Dec 2, 2010 | 12:41 AM
LVC5A6's Avatar
Default Turn signal flasher probem
2002 Audi A6 3.0 problem is a weird buzzing noise coming from above the radio / ac vents. I have read the other threads and every other thread I read is the noise is happening before the turn signal is used and this issue is after the turn signal is used. Is this the turn hazard switch or the turn signal switch ? ? Thanks
Old Dec 5, 2010 | 04:27 AM
LVC5A6's Avatar
no one ?
Old Dec 5, 2010 | 08:53 AM
bob martin's Avatar
First, try further isolating the source of the noise by using a long screwdriver as a stethescope. If you find the noise is coming from the hazard switch, replace it. If not, let us know the source location of the noise.
Old Dec 6, 2010 | 01:16 AM
LVC5A6's Avatar
will do thanks..
Old Dec 10, 2010 | 08:37 PM
LVC5A6's Avatar
the noise is def coming from the switch. Replacing soon and will report back.
Bklynrx7
May 8, 2011 01:30 AM
scorpionking0102
Mar 12, 2010 03:38 PM
xman58
Oct 6, 2008 09:45 AM
