Two QUestions
1) The level sensor on my windshield washer resevoir keeps popping out and draining my fluid. Is there any way I can make sure it does not fall out again?
2) This one is really weird. When I turn on my rear window defroster, my radio goes staticy. All but a few of my stations will get nothing but static. When I turn it off it goes back to normal. Anyone else ever have this problem, and if so how do you fix it?
BTW it is a 2004 A6 2.7 S Line with Bose sound system.
1 - glorified glue.
2 - yes. Probably a "rebuilt in China" POS using the cheapest diodes, capacitors and resistors. The capacitor/resistor pair should dampen out the electronic noise that is sneaking into your rear window defroster that then sneaks into your radio signal.
