Universal Synthetic ATF
A local shop offers tranny flush (triptronics) with BG Universal Synthetic ATF.
http://www.bgprod.com/blendr/syntheticATF.html
The fluid is red in color and compatible with DextronIII/Merkon and Equivalent to Audi Vw G 052 162 A2 (prints on the case ).
(no mentioning about ESSO LT71141). Price is more than 3x cheaper than the WV fluid.
Looks like revolutionary solution as no other fluid claims compatibility with all ATF aplications.
The shop manager claims no issues using BG Universal Synthetic ATF in any VW or Audi trannys.
Does this sound for real?
Any experience with that ATF?
I have generic synthetic ATF in my Tip from Kennedy Transmission. I would say about 3/4ths of mine is generic and I have had zero (knock on wood) problems in 2 years now. Theirs was tan, but I don't see how the color makes any difference. But Blue would be kinda fun.
My Audi parts supplier/expert provided me with a non-Audi WV synthetic tranny fluid for my 97 A6. I asked him if it was OK and he said that it was approvred by VAG for my vehicle but was not approved for the newer vehicles. I did not ask him for the definition of a newer vehicle.
BAsed on the application charts attached, one could say that '98 was the border year for new tiptronics that required Esso ATF.
My understanding is that Dextron III and Esso are not compatible.
On the other hand Castrol Multivehicle ATF claims compatibility with both Dextron III and Esso LT 71141.
I think there is difference if the ATF is added by drain out or complete flush- the quantity of the old fluid could mask eventual deficiencies of the new ATF...
Thx,
no attachments were done due to the size limits.
I have to figure out how to publicize them or PM to interested members.
Thx,
These are the links for access with gmail accounts... sorry
http://docs.google.com/fileview?id=F...c-6f1507c02186
http://docs.google.com/fileview?id=F...c-f8ea1b5dd0ff
http://docs.google.com/fileview?id=F...119b33ea&hl=en
nemohm - I think your correct about the dividing line being the trip...
In any case draining all the fluid is more than just removing the trans pan. The torque convertor has a ton of fluid in it and getting it empty is not simple...
My bimmer requires ESSO LT as well, but I've switched to Mobil One synthetic ATF with no problems. Apparently there are a lot of ATF's compatible with ESSO now.
According to the Mobil One website:
Mobil 1 Synthetic ATF
Synthetic Automatic Transmission Fluid
New Formula - Mobil 1 Synthetic ATF is designed to provide significantly higher levels of performance above conventional fluids in most domestic and imported passenger vehicles.
The synthetic base oil enables excellent performance even in the severest of operating conditions. It offers outstanding gear shifting and power transfer performance versus conventional ATF fluids. The inherently high viscosity index and stability of Mobil 1 Synthetic ATF help protect against thermal breakdown at high operating temperatures, while still providing outstanding performance at very low ambient temperatures.
Mobil 1 Synthetic ATF combines high-performance synthetic hydrocarbon base oils and a superior balanced additive system to provide significantly higher levels of performance above conventional fluids. This unique, advanced technology provides long drain capability, excellent friction retention, and low-temperature fluidity. Further, it helps to improve overall transmission durability and cleanliness. Mobil 1 Synthetic ATF is also compatible with conventional ATFs.
Mobil 1 Synthetic ATF is formulated for use in most North American, European and Asian vehicles.
Approved for Allison C-4 applications
Exceeds JASO 1-A performance standard
Also suitable for use in vehicles that specify the following fluid requirements:
Audi G 052 025-A2, G 052 162-A1
BMW LA2634
Esso LT 71141
ETL-7045E, ETL-8072B, N402
Ford* MERCON*, MERCON V, MERCON LV
All 2005 and earlier GM vehicles**
Honda ATF-Z1*
Hyundai SP-II, SP-III
Idemitsu K17
JWS 3309
Kia SP-II, SP-III
MAN 339F, V1, V2, Z1, Z2, Z3
Mazda ATF-III, ATF-MV
Mercedes-Benz 236.1, 236.2, 236.5, 236.6, 236.7, 236.9
Mitsubishi Diamond SP-II, SP-III
Nissan Matic-D, Matic-J, Matic-K
Subaru ATF
Toyota T-III, T-IV
Voith 55.6335.XX (G607, G1363)
Volvo 97340
ZF TE-ML 03D, 04D, 09, 14A, 14B, 16L, 17C
* Not recommend for CVT applications, MerconŽ SP, Ford Type F
** Mobil DEXRON-VI ATF is recommended for 2006 and newer GM vehicles and improved performance in 2005 and earlier vehicles, wherever DEXRON is specified.
Automatic transmissions should be checked for proper fluid levels at regular intervals, and the fluid should be changed at manufacturer-recommended intervals. However, this may vary due to your vehicle's operating conditions. Some manufacturers recommend more frequent changes of transmission fluid under severe driving conditions, such as heavy traffic, hot weather and trailer pulling.
Now, I've read some posts saying that although it's compatible with the ESSO called for in BMW trannies, Audi trannies are a little different and could damage them. All I know is to be on the safe side, I'll order the blauparts kit which comes with OEM pentosin ATF.
BMW LA2634
Esso LT 71141
Honda ATF-Z1*
Idemitsu K17
JWS 3309
Kia SP-II, SP-III
Subaru ATF
Toyota T-III, T-IV
Volvo 97340
