UP DATED-wondering to the right
Old Feb 5, 2008 | 10:30 AM
james0013's Avatar
Default UP DATED-wondering to the right
Hi guys, little problem with my A6, when you are driving the car streight along the road it has a tendency to wonder off to the right. It can be kept in a streight line by holding the stering wheel to the left. I have had an alignment done and that did not seem to corect the problem any ideas what else could cause this. The car has not been in a accdent acording to carfax or autocheck and has been maintaned regualy.
Thanks.
James
Old Feb 5, 2008 | 11:23 AM
Jeffla's Avatar
Default RE: wondering to the right
Tire pressure, the tires itself, I have two sets of all season tires. The one set drives straight and my newer pair pull to the right. I have no idea why one set would pull and not the other. I have rotated the tires several times and they still pull to the right. But when I put on my older set of wheels, all is well and the car goes straight down the road. So it must be the tires themselves. Not to helpful of a post I will admit.
Jeff
Old Feb 5, 2008 | 12:15 PM
james0013's Avatar
thanks Jeff, I am going to have the blance of the tyres checked when i goes into the shop tomorow. I am wondering if itcould be the sway arms or pther components of the stering.
Old Feb 5, 2008 | 12:18 PM
NH_USA's Avatar
A drift to the right is not all that bad - at least it is conservative and not a left wing liberal.
Possible causes for not going straight -
Alignment
--- toe etc
--- wheel base different on each side
--- stearing wheel not centered
--- all the things a good alignment shop checks
Tire pressure
Tire OD
Incorect tire rotation -some tires have arrows showing the required rotational direction
Worn components that do not show up during alignment
Old Mar 22, 2008 | 09:58 PM
james0013's Avatar
Ok I put a new tire on theleft front and that made the pulling much worse, I did put the spare on therightside which was viretualy newto see if this improved things. sadly no joythere. I have checked the depths on the other tires, the left rearhas significant less tred on it than the other three. I am going toput 4 new tires on, balence andhave it 4 wheel aligned see whathappens.That should curethe wondering to the right should it not? that could cause a pull with the car being a Quattro.
(I called the audi dealer and they said that miss matched tires(in terms of ware and tread patern) could cause apull to the right and I heared the same from two other mechanics who I trust).
Old Mar 22, 2008 | 10:03 PM
formulagigi's Avatar
^ true.... It can.
I am assuming you've checked tire pressure?
YOu need a good alignment
Old Mar 22, 2008 | 10:09 PM
james0013's Avatar
yes checked tire pressure first. (cheapest thing to do)
Old Mar 22, 2008 | 11:32 PM
james0013's Avatar
This couldbe a bit of a long shot but if the tiers do not work, the next place I was going to look was the relay for the speed sensitive steering, could that be bad and cause a pull to the right? the other thing I was going to look at was the rack for leaks.
thanks
James
Old Mar 22, 2008 | 11:37 PM
trapped's Avatar
Hmm mine does the same thing, its only slight, but I'm glad its to the right because its better than crashing into oncoming traffic.
Old Mar 23, 2008 | 09:43 AM
Khardysius's Avatar
Something else to keep in mind are brakes. If one of your calipers on the right is seizing/rubbing the rotor this may havea minor effect.
The only other thing I can think of, and this may be a long shot, but the wheel speed sensor may be off and rotating slightly slower than the others.
Best guess is that your have bad tires, balance, or alignment.
