AudiForums.com
-   Audi A6 (https://www.audiforums.com/forum/audi-a6-9/)
-   -   upper control arms (https://www.audiforums.com/forum/audi-a6-9/upper-control-arms-141582/)
cardiffkid Nov 8, 2009 09:00 PM
upper control arms
Hi, I'm looking at changing the upper control arms on my 2000 Audi A6 4.2. I've already got the arms , just need to know the best way to go at changing then out. Thanks for any advise Ken
Jackmup Nov 8, 2009 11:58 PM
Remove the wheel.
Spray the crap out of the bolts with liquid wrench.
Completely remove the bolt from the housing that holds both upper arms in - the arms are notched so it must be completely removed.
Remove the bolts holding them into the upper wheel well and that's that. The front inner bolt may be in back wards so unbolt the strut mount and tilt it out. I cut mine and installed it the other way by persuading the spring out of my way but my bolts were not corroded. If yours are that would be a mistake because you will need to spin the bolt out.
bob martin Nov 9, 2009 06:17 PM
One other thing: don't tighten the new arms all the way until the car is sitting on the ground.
Bob
