Using the cam lock tools on an A6 3.0L heads
Old Oct 6, 2010 | 08:13 PM
02AudiA63L_65's Avatar
Default Using the cam lock tools on an A6 3.0L heads
I just finished replacing valve seals and bent valves on both heads. I must have gotten lucky by placing the cam locks on the driver head and all valves are closed.
However, i noticed that the passenger head has open valves when the cam lock tool is on. It sort of makes sense since the pistons are down on those cylinders. But, I just need to make sure before I put everything back together and I doesn't run properly or even at all.
Old Oct 7, 2010 | 09:34 AM
bob martin's Avatar
That is normal. The passenger side cam is riding on some lobes when the timing is in the proper position.
SOunds like you are making good progress!
Bob
Audi_Eric
Nov 10, 2011 02:01 PM
nypapaya
Aug 2, 2010 10:45 PM
MPLSChase
Jun 9, 2009 04:22 PM
Wayne.L
May 14, 2008 12:38 PM
Duke52
Oct 19, 2006 07:29 PM
