VAG COM CABLE FROM EBAY
I want to buy this VAG COM cable from ebay:
http://cgi.ebay.com/ebaymotors/USB-K...spagenameZWDVW I also got the VAG COM 409.1 software recently, I wanted to know if this cable is the same one "they" use to do thing such as reset airbag lights and such.. Will this cable work with the VAG COM cable. Is it good, same as say the ones for $100+ from the ross tech site. Thanks |
RE: VAG COM CABLE FROM EBAY
yes it will work they will send you a way to crack the vagcom program with the ebay cable... you can only use the 409 software with the ebay cable not the newer releases and also you need to buy they 100 dollar licence to vagcom from rosstech in order to get total functionality of the program
ORIGINAL: joetm yes it will work they will send you a way to crack the vagcom program with the ebay cable... you can only use the 409 software with the ebay cable not the newer releases and also you need to buy they 100 dollar licence to vagcom from rosstech in order to get total functionality of the program |
Can you point me to instructions for re-coding the transmission and adding a new remote control key?
TIA. |
Please refrain from thread jacking and use the search button.
ORIGINAL: Asianicestyles Please refrain from thread jacking and use the search button. what r u talking about? |
here is the thread for the recode its like the 2nd or 3rd post down
https://www.audiforums.com/m_826204/tm.htm enjoy also if you have an sline or allroad it should be 01032 regular a6 2.7s n 4.2s are 00032 |
can you guys point me to where i should start, like some manual, diy or something.. or some alternate programs i should use with my cable when i get it. first i want to reset airbag light and then do the open/close windows with remote mod.. where do i start..
thanks |
If you have any other cars I would Highly suggest buying the license, because with out it there is not much you can actually do.
On the plus side if you want to control your windows with your remote this will help you http://www.audiworld.com/tech/elec36.shtml if you haven't already checked out Audi world you really should there is a lot of good info and DIYs on there as well. Also a note, when you do get your cable make sure you remember which port you have pluged the cable into on your laptop. I had problems with this as well, If you plug your cable into say port one, on your laptop besure to select COM 1 on the vag com options and then go and test the connection. |
what do i do.. i installed the software they gave me. its "vag com -release 409.1". my laptop doesnt seem to read the car.. i installed drivers allso but i cant do anything in the program just a bunch of errors
