valve gasket in INDY
Hello folks~
I went to Indy mechanic for changing a valve gasket. And the mechanic said I need to change the cover gasket as well as valve gasket. I have no idea what the differencesare between gasket & cover. Of course they charge laborof two jobs. Somebody has an idea? Thanks. |
RE: valve gasket in INDY
I don't know what this mechanic is trying to do to you but there is ONLY a valve cover gasket and cam adjuster seals under the valve cover.
The valve cover comes with the center part that goes around the spark plug holes. Look up a picture of it on www.ecstuning.com |
O ring is also one of the valve cover gasket?
mechanic said need some special tool to change the o ring he is su**s |
There is only the valve cover gasket, and half moon cam seal which requires a special tool to get at. If he's talking about the cam seal then he is correct.
