RE: Vanishing Antifreeze
What could be the problem under the plenum...and what do you mean by that? Also, where does that hose connect to? Isit bad to drive it like that?
And it seems that the Antifreeze leak sort of slowed down...its weird...I am not loosing it as much. |
the coolant pipes on the v6 run under the pentium and very common for leaks due to expansion of the clip/clamp or hardened pipes
Great thank you.I will check it out tonight. Also, would you happen to know where that breather hose would connect to?
ORIGINAL: MiniSpdRcr Great thank you.I will check it out tonight. Also, would you happen to know where that breather hose would connect to? |
