VR6 12v vs. 2.8L 30v
Old Jun 19, 2008 | 03:15 AM
qwnzr's Avatar
Default VR6 12v vs. 2.8L 30v
Is it possible to use, say the turbo manifolds from the VW VR6 12v engine for the old 2.8L 30V audi engine? like.... these http://search.ebay.com/search/search...p=1&fsoo=1 ?
Old Jun 19, 2008 | 08:00 AM
massboykie's Avatar
Member
Default RE: VR6 12v vs. 2.8L 30v
ORIGINAL: qwnzr Is it possible to use, say the turbo manifolds from the VW VR6 12v engine for the old 2.8L 30V audi engine? like..
hey Qwnzr
Nope, I do not believe so. The VW VR6 is a narrow angle V6 (15 degrees I believe). It is not a regular V6 with two seperate banks of cylinders, it's more like a straight 6.The big difference isint the exhaust manifold, where the VR6 is one unit, as all the exhaust ports come out of the head on the one side. Onthe 2.8 the exhaust ports will come out on either side of the "V" (one on each back of the V),so you would probably need something like this that is used on the S4 2.7T: http://cgi.ebay.com/ebaymotors/2000-...mZ150259726315
I don't think the 2.7 manifolds will fit the 2.8, but I may be wrong. Another option is supercharging the 2.8. There are some kits out there, but they are quite expensive. You might be better off just getting an S4. I think PEShas a kit: http://www.pes-tuning.com More tuners on here http://www.VAGLinks.com
Cheers
Massboykie
Old Jun 19, 2008 | 10:58 AM
qwnzr's Avatar
Go figure nothing works on the 2.8L :/ I thought the manifolds for the VR6 looked a little wierd though...
Thanks anyways
Old Jun 19, 2008 | 02:15 PM
oc_audica's Avatar
i've read that the B5 RS4 manifolds are similar
Old Jun 20, 2008 | 03:00 PM
joetm's Avatar
i have manifolds for my 2.7 02 and i am tryin to get rid of them ... brand new!!
Old Jun 20, 2008 | 05:43 PM
massboykie's Avatar
Member
ORIGINAL: joetm i have manifolds for my 2.7 02 and i am tryin to get rid of them ... brand new!!
Hey Joe
I see you have the OBX manifolds... Did you find a difference after installing them? Did you do it while the motor was out for something else? I was looking at those on eBay, but I don;t want to pull the motor just for that, so I would hold off until I need turbos again...
Cheers
Massboykie
Old Jun 25, 2008 | 02:37 PM
joetm's Avatar
ehh not really a noticiable difference but if you are going to get the k04s they are a nice piece to have
all polished stainless they are pretty sweet
pea pullin gthe motor is a B*tch but i had some time on my hands plus I wanted to get a look at all of the rubber components as a lot of them were starting to crack and break off and I had massive leaks
