water in passenger footwell, help!!!!!!!!!
Did you make sure the drains under the battery tray are clear of debris? That is a common source of water int he passenger footwell. You would need to remove the battery, and remove the tray on which the battery sits to get at the drain in question.
Other sources include:
-windshield cowl not installed properly
-clogged sunroof drains
-clogged a/c evap drain
Best of luck!!!
Best of luck!!!
Oh, and here is a post that shows you how to get at the drain under the battery tray, and contained within this post is a link on how to remove the battery itself:
http://forums.audiworld.com/showthread.php?t=1723534
Also check your Cabin air filter.
If it is wet then the plastic strip at the bottom of the windshield might be leaking. You need to carefully pry it out and clean the debris under it. Then push it back in. I used a light coating of silicone in the channel and used some black along the top where it meets the window.
Mine was leaking and dripping into the cabin air filter.
hdieffenthaller@gmail.com
Aug 6, 2010 02:06 PM
