Water pump & thermostat while replacing timing belt?
Old Oct 2, 2009 | 02:16 PM
dhn0906's Avatar
Default Water pump & thermostat while replacing timing belt?
I am about to replace the timing belt on my 2001 Audi A6 2.7T(92000miles) through a mechanic. He recommends that I replace water pump and thermostat with the timing belt. I know that the timing belt is very crucial and its something that should not be postponed but how about the water pump and thermostat? I also hear that those two items can wait until 130~140k miles. If so, I will not replace it since I am looking forward in selling my car at that time. Please comment on what I think. Thank you!
Old Oct 2, 2009 | 02:22 PM
ryuuoh's Avatar
The common thought is to replace thermostat, water pump, tensioner, idlers, and any leaking seals.
Old Oct 2, 2009 | 03:00 PM
hxgaser's Avatar
Do it. $150 peace of mind. When the $20 thermostat fails after the timing belt job because you wanted to save some dough, you will be paying another $800 for labor alone.
Old Oct 2, 2009 | 04:36 PM
kprc51's Avatar
Cam seals,
Thermostat,
Water pump,
Crankshaft seal
All idlers
If you are keeping the car for longer than six months, DO IT. This stuff now costs pennies compared to what you might have to spend later if any of these go south.
JR
Old Oct 2, 2009 | 08:13 PM
TwinTurboC5's Avatar
Default TB Job
Hi, I agree with the others. Changing those parts is cheap insurance that could save you a bundle in labor if the water pump goes out 10k miles after the TB Job.
You should also consider the added value for resale if you decide to sell your car and can provide a potential buyer with receipts showing the work has been done.
Old Oct 2, 2009 | 08:39 PM
ryuuoh's Avatar
@dhn0906,
BTW, the reason timing belts fail is one of the components seizes, throwing the belt off time and destroying your valves.
Old Oct 2, 2009 | 11:28 PM
vrso2's Avatar
100% yes !!!
Old Oct 3, 2009 | 05:28 PM
gone postal's Avatar
From: Nation's oldest city, FL (screw you Jamestown)
Originally Posted by ryuuoh
@dhn0906,
Exactly!! Not to mention the water pump's impeller is plastic. Plastic over a period of years and tens of thousands of miles of constant heating/cooling cycles becomes brittle. Once a blade breaks off or chips, it is no longer in balance and the unit essentially grenades itself. That of course results in a thrown timing belt and big a$$ paperweight for a motor. It's stupid NOT to change pump, thermostat and idler pullies and if I were a shop, wouldn't even do the job any other way.
PS - replacement pumps have metal impeller - selling point to new owner
brrman
Mar 10, 2009 02:40 PM
Frails
May 8, 2007 07:13 PM
audigirl1982
Mar 29, 2007 02:08 PM
techbod
Jan 24, 2006 01:17 PM
pciguru
Nov 2, 2004 11:43 AM
