Weak Brakes
My brakes seem to have gotten alot weeker the last week, I was hoping that it was me just being picky, but now my dad has noticed. There are not being as crisp and strong as I remember... last week... haha what should i do? can it be the amount of brake fluid?
thanks for any help. |
RE: Weak Brakes
What year A6? What engine? Any fault codes in the brake electronics? Is the brake fluid low? How many miles are on the car?
RE: Weak Brakes
ORIGINAL: a6in My brakes seem to have gotten alot weeker the last week, I was hoping that it was me just being picky, but now my dad has noticed. There are not being as crisp and strong as I remember... last week... haha what should i do? can it be the amount of brake fluid? thanks for any help. Then come back to us. |
RE: Weak Brakes
ORIGINAL: auditech79 What year A6? What engine? Any fault codes in the brake electronics? Is the brake fluid low? How many miles are on the car? |
RE: Weak Brakes
If your brake fluid was extremely low, it would behave as you are describing. If the fluid is low, you are getting air in the system and since the brakes are hydraulic they need fluid to work. If the fluid is full, buthas never been changed, you may have contamination that could cause the same problem. My first instinct in that situation would be to completely flush and bleed the brakes with good fluid. That is the simple solution to your problem. You may also have small leaks in the brake lines, my A4 was notorious for this where the lines entered the caliper.
The other issue may be a malfunctioning ABS module, but that should throw a code if it is going out. |
