Weak Brakes
Old Jan 16, 2008 | 09:31 PM
a6in's Avatar
Default Weak Brakes
My brakes seem to have gotten alot weeker the last week, I was hoping that it was me just being picky, but now my dad has noticed. There are not being as crisp and strong as I remember... last week... haha what should i do? can it be the amount of brake fluid?
thanks for any help.
Old Jan 16, 2008 | 09:39 PM
auditech79's Avatar
Default RE: Weak Brakes
What year A6? What engine? Any fault codes in the brake electronics? Is the brake fluid low? How many miles are on the car?
Old Jan 17, 2008 | 12:00 AM
tsbpenguin's Avatar
ORIGINAL: a6in
Uhh step 1, check your pads.
Then come back to us.
Old Jan 18, 2008 | 02:11 PM
a6in's Avatar
ORIGINAL: auditech79
Its a 2002 a6 fwd 3.0 with 68,000 miles. I dont have any faults codes. How do I really check to see if my brake fluid is low? Just a couple months ago my steering fluid was out and no warning, or notice came up so I'm guessing I may be low on fluid. Would fluid be resonsible for moments of strong brakes but then all of a sudden that strength gives out, than comes back, gives etc.
Old Jan 18, 2008 | 02:20 PM
NJGOAT's Avatar
If your brake fluid was extremely low, it would behave as you are describing. If the fluid is low, you are getting air in the system and since the brakes are hydraulic they need fluid to work. If the fluid is full, buthas never been changed, you may have contamination that could cause the same problem. My first instinct in that situation would be to completely flush and bleed the brakes with good fluid. That is the simple solution to your problem. You may also have small leaks in the brake lines, my A4 was notorious for this where the lines entered the caliper.
The other issue may be a malfunctioning ABS module, but that should throw a code if it is going out.
Acidic
Jan 28, 2013 01:54 PM
oleg20
Apr 21, 2012 11:56 PM
alias747
Oct 15, 2007 04:07 PM
