What kind of oil?
Old Apr 5, 2009 | 10:06 PM
muras100's Avatar
Default What kind of oil?
What kind of oil is better for my 2001 A6 2.7T - 5w-20 or 0W-40? Thanx
Old Apr 5, 2009 | 10:20 PM
Midniteoyl's Avatar
The 0w-40.. 20 is waayy to thin.
Old Apr 5, 2009 | 10:25 PM
Jeffla's Avatar
Old Apr 5, 2009 | 10:45 PM
nm3210's Avatar
To make this more understandable (no offense):
• 5w-20 is going to be too thin for normal use - ever (well most usually)
• 0w-40 sounds good enough
It's not an exact science, and your choice of oil should really depend on the climate that you are typically driving in. For a warm climate you can pick a thicker, lower viscosity oil such as 5w-30 or maybe even 10w-30. If it's cold, then it's good to use a thinner oil - this will make it easier to crank over the engine when the oil is cold.
Old Apr 6, 2009 | 05:22 PM
muras100's Avatar
Default Thanx
Actually, I use 5W-20 , engine runs smoothly and I am living in nothern Illinois where the winters are harsh. The reason I asked is cause I found note on mobile1 site that 0w-40 is recommended for most european cars with turbochargers while 5w-20 also for turbocharged but mostly japanese. The 5w-20 was recommended for me by guys working in oli lube shops , so...I have to choose who 's talking truth:\
Old Apr 6, 2009 | 05:27 PM
zippy_gg's Avatar
Talking
Originally Posted by Jeffla
That's funny Jeff!
Old Apr 6, 2009 | 05:55 PM
Midniteoyl's Avatar
Arent you suppose to use VW 502 rated oil? The 0w-40 is...
Forget what the ricers at the local oil boob shop say..
The mobil 1 0w-40 has more ZDDP which helps protect the engine... Its at 1000ppm vs no more than 800ppm for the 5-20 (new standard). They can use more by calling it 'european formula'.
The Modil 1 5w-40 has 1200ppm...
Old Apr 6, 2009 | 06:25 PM
muras100's Avatar
So 0w-40 in my case is better choice. Thanx a lot.
Old Apr 6, 2009 | 06:31 PM
muras100's Avatar
Default I meant
5w-40. It repeats most on that VW 502 list.
Old Apr 6, 2009 | 06:36 PM
muras100's Avatar
Default But...
its recommended mostly for diesel trucks.. So 0w-40.
