What motors re-place the 2.8 30v
Old Jul 24, 2008 | 09:21 PM
mudduck's Avatar
Default What motors re-place the 2.8 30v
Does anyone know?
Old Jul 24, 2008 | 10:04 PM
marko_tomas13's Avatar
Default RE: What motors re-place the 2.8 30v
What do you mean by replace?
You want to swap a motor or do you mean what came after as in what was offered after the 2.8 was available?
Old Jul 25, 2008 | 11:17 AM
hxgaser's Avatar
You replace 2.8 with a 2.8, unless you want to spend an extra few grand. Even so, it is not as easy as swapping Chevy small blocks or Honda B series.
Old Jul 25, 2008 | 12:03 PM
oc_audica's Avatar
2.8 was replaced by the 3.0
3.0 was replaced by 3.2
is that what you mean?
Old Jul 25, 2008 | 11:43 PM
mudduck's Avatar
Just wondering what motor van re-place mine.VW.
Old Jul 27, 2008 | 07:13 PM
mudduck's Avatar
Sorry have problems posting.I see a alot of motors with letters after them like AHA,etc......Whould like to know what mine is.I found a 2003 vw motor 2.8 30v,would like to know if it would fit in my car.1999 a6 avant quattro.
Old Jul 29, 2008 | 01:35 PM
dbacon89's Avatar
Asking in english may help you with your answers.
A passat and an A6 are the exact same cars. other than the exterior, everything under the car is the same.
If you can find and A6 engine, I would go with that. If you can find a 2.8 passat engine, that will work too.
Old Jul 29, 2008 | 01:48 PM
oc_audica's Avatar
99 A6 has an AHA motor
2003 won't work because it is DBW, and yours in Non-DBW
Old Jul 30, 2008 | 10:02 PM
mudduck's Avatar
Thanks Oc audica,In english what is dbw vs non-dbw.
Old Jul 30, 2008 | 11:23 PM
oc_audica's Avatar
Drive by wire (or Non-Drive by wire)... your throttle is not electronically controlled. ECU is also different.
zandrew
Feb 16, 2013 09:25 AM
trev123
Sep 2, 2012 10:54 PM
savagebeast
Aug 20, 2008 09:32 AM
2000S4
Dealerships
Nov 17, 2006 07:57 AM
92GalantVR4
Jun 11, 2006 04:48 PM
