Whats a TBB?
Thanks guys I just had the Timing belt changed so if it is that then there is a problem but I will either check or have checked the Throttle body boot.
Would that been torn throw the codes P1411 and P1423?
also what would be the consequences of it being torn?
boosts and then studders as charge air leaks out of tear, A large boost leak is something you only have to experience and wonder about once, everytime after the first you will know exactly what is happening
