Where is the fuel filter?
Old Jul 9, 2007 | 07:45 PM
alias747's Avatar
Default Where is the fuel filter?
On the 2.7 engine, Anyone got a reference pic or something? Thanks!
Old Jul 9, 2007 | 07:50 PM
auditech79's Avatar
Default RE: Where is the fuel filter?
Big silver thing on the side of the gas tank right in front of the right rear wheel.
Old Jul 28, 2007 | 10:10 PM
Cmoney's Avatar
right where auditech said. It has a band around it that can be hard to loosen. There will be a lot of gas spillage so get some towels, rags, or newspapers.
Old Jul 28, 2007 | 10:29 PM
thetryal's Avatar
what is a good mileage to change the fuel filter??
Old Apr 30, 2008 | 05:32 PM
rh1231979's Avatar
Is there a special Audi specific tool to remove the bolt that holds the band/filter? The one on mine looks like a "torx" type but has a different design.
Old Apr 30, 2008 | 05:40 PM
lowell513mx's Avatar
i replaced mine at 78,000 miles just after i bought it. i didn't use any special tools to change mine out.
Old Apr 30, 2008 | 06:30 PM
CaptTrev's Avatar
do you need any new seals or o-rings or anything or just a new filter?
any tricks for not making a mess?
Old May 1, 2008 | 12:49 AM
rh1231979's Avatar
lowell513mx, what did you use to remove this bolt? :
[IMG]local://upfiles/52629/FBFBD072368946158F65D32976402BBF.jpg[/IMG]
Old May 1, 2008 | 12:58 AM
TopGUn86's Avatar
try and get some vice grips on it if you dont have the tool
Old May 2, 2008 | 02:54 PM
hxgaser's Avatar
ORIGINAL: CaptTrev
It is nice to buy new metal washers. You need total of 4, 2 of them are smaller than the other 2. As for not making the mess, pull your fuel pump fuse out, run the car until it dies, then crimp the inlet and outlet lines with line crimpers. Otherwise, you will have fuel spraying everywhere, like I did.[&o]
