where is the transmission fluid and stick on 2000 a6
Old Jun 11, 2008 | 03:15 PM
sollyd25's Avatar
Default where is the transmission fluid and stick on 2000 a6
where is the tranny fluid and dipstick on a 2000 audi a6 4.2?
Old Jun 11, 2008 | 03:20 PM
techbod's Avatar
Default RE: where is the transmission fluid and stick on 2000 a6
is it an autobox or manual?
Old Jun 11, 2008 | 03:27 PM
techbod's Avatar
put it another way is it tiptronic which is automatic but digital
Old Jun 11, 2008 | 06:11 PM
sollyd25's Avatar
it is auto with the tiptronic.
Old Jun 12, 2008 | 01:07 AM
Jeffla's Avatar
There isn't one.
Old Jun 12, 2008 | 10:11 AM
beng's Avatar
Tranny fluid is in the tranny.
You check the level by pulling the plug out of the bottom of the tranny.
If the fluid runs out when you pull the plug, your fluid level is good.
But this has to be checked at given temperatures, meaning if you were to check it when it's to hot it might run out, but at a cooler temp it might not.
also, the car has to be level. someone correct me if'nI am wrong? BENG
Old Jun 12, 2008 | 04:05 PM
nemohm's Avatar
Engine running; N
There are 2 plugs, look for the bigger; no fluid should come out if the level is accurate; make sure the level is not low - just add fluid till get dripping out.
Old Jun 12, 2008 | 05:24 PM
gottwinns's Avatar
also you should check it when its around 80 degrees out side to get a better reading
Old Jun 12, 2008 | 06:17 PM
auditech79's Avatar
You have to monitor the transmission temp with the VAG COMthen pull the plug when it reaches around 32*C, the vehicle also has to be in PARK when checking it un-less its a CVT. (front wheel drive)
Why do you wanna know anyway? You shouldn't be messing with it un-less its leaking.
Old Jun 12, 2008 | 07:49 PM
sollyd25's Avatar
reverse won't catch and i heard 'clean out the valve body by flushing the fluid'. soi thought i'd try that first
