Will my A6 alignment be in factory specs after lowering springs?
Old Mar 26, 2008 | 09:33 AM
dale_gribble's Avatar
Default Will my A6 alignment be in factory specs after lowering springs?
I can't get a straight answer from Eibach or any one on this. If I put Eibach sport springs on my stock 2.8 A6 quattro, can I get the car in factory alignment specs?
My concern is that I don't want to burn through tires or put excessive wear on suspension components.
Thanks!
Old Mar 26, 2008 | 09:47 AM
Default RE: Will my A6 alignment be in factory specs after lowering springs?
Time to get rid of this unsightly wheel well gap...
Old Mar 26, 2008 | 09:50 AM
techbod's Avatar
wheel gap will be the issue but as for being standard to original spec ( no it wont ) you are altering the center of gravity so it should be checked
Old Mar 26, 2008 | 10:52 AM
formulagigi's Avatar
Your camber will be off in front and can't be adjusted unless you have a camber kit...
I personally like a little camber but if you rotate your tires often and regularly, you should limit the uneven wear...
Old Mar 26, 2008 | 10:59 AM
techbod's Avatar
^ agreed
Old Mar 26, 2008 | 11:10 AM
h8state's Avatar
If you were to have a tire shop do this what would be the cost to lower and
How much for parts?
Just curious, I am a newbie but would like to have it done, justdon't have the time and also want it done right.
I have an 01 that looks JUST LIKE the one in the pic...
Old Mar 26, 2008 | 11:14 AM
to do an aignment?
if so, you definitely need a shop and not all are equipped to perform alignments
or install springs?
heard they are a PITA, count 4-5hours labor charge IMO
Old Mar 26, 2008 | 11:22 AM
techbod's Avatar
not my area realy but have heard coilovers are best because the are adjustable but expensive
Old Mar 26, 2008 | 12:58 PM
OK it is a very open question, for the best answer we would need to know what you are looking for, what your budget is... do you track the car? are roads bad in your area? do you favor low ride and better handling over comfort....
I would say the following:
Coil overs are very good byt very expensive and much more more than what 90% of drivers need/want. They also tend to be rough on our cars. PSS9's are real nice and adjustable not only in height but also in dampening, but count on paying 1500-1700 plus 4-5 hrs labor at whatever rate your shop charges.
Springs only: If you have the regular (non sport) suspension, I would not recommend it as it will ruin your shocks super fast, especially if you go for the low H&Rs wich have a more aggressive spring rate than the Eibachs. If you have sport suspension, it is ok to run springs only HOWEVER it is MY EXPERIENCE on my A6 that it is not a good idea as it still wears your shocks faster and the car will bounce and bottom out more in some areas. If you ahve sport suspension and want to do springs only, I would recommend the Eibach kit. it is less aggressive, therefore not as low and more comfortable but will cure the 4X4 look
I did springs only (H&R) and regretted it so then I aqdded shocks.... not a good idea, i basically paid labor twice... so learn from my mistake Save long term
Springs and shocks: a common option because it is 500-1000$ cheaper than coilovers typically and more than enough for 90% of A6 owners who don't track their cars and just want the better look and improved hanlding. But here again choices choices choices... which shocks and springs? Depends on what you are looking for....
I had Koni yellows/sport shocks with H&R Sport springs. Ride sat real low, looked awesome and handled like a ... 4000lbs race car However, my wife and kids did not like the ride at all. Pretty rough on bad roads.
So now I sold that set and had installed Koni FSDs (adjustable based on driving, so softer on bad roads, bumps... for comfort and harder in cornering for improved handling.) and Eibach springs.
The car is not as low, especially in the back and does not handle quite as well, but I get about 80+% of the handlinf form my previous suspension set up and comfort close to stock in 90% of road conditions. I LOVE THAT SET UP! The combo is set as a kit, tested and approved by Koni, otherwise they don't recommend their FSD with lowered acrs. So money well spent.
Old Mar 26, 2008 | 01:17 PM
h8state's Avatar
Thanks, just looking to lower the ride...cause i'm cool like that
Just wondered what it would entail and costs to lower...
