Will these fit my 2.7t??
Old Mar 31, 2006 | 06:48 PM
xcharrier's Avatar
Default Will these fit my 2.7t??
I'm having a hard time finding wheels that will fit my 2000 A6 2.7t... I'm assuming because of the large caliper. Anyway... I was wondering if anyone knew if these would fit.
Mille Niglia VR - The wheels are 18"x8" Offset 45 (All Four), with 5x112 bolt pattern. And the plan was to put 245/45/18's on.
Any help would be greatly appreciated. Thanks.
Old Apr 1, 2006 | 09:59 PM
Cmoney's Avatar
Default RE: Will these fit my 2.7t??
ORIGINAL: xcharrier
I have a 2000 A6 2.7T. I went with a 18X8.5, 35mm offset, and 5X115 bolt pattern. I had to use a 35 mm spacer to clear the front brakes. Don't use a generic spacer. Wheel will come off. I used a 35mm spacer by Eibach that was made specifically for our cars. They were $72 a set and came with extra long lug bolts. I can send you a pic of my car if you want to see what they look like. Good luck buddy.
Old Apr 1, 2006 | 10:12 PM
Cheese Eater's Avatar
go to www.1010tires.com and www.tirerack.com to use the calculator on 1010 and tirerack will get you to 90% towards the largest set of wheels your car can take, along with the wheel width and thickness that can fit without modification.
Old Apr 3, 2006 | 03:29 AM
928sho's Avatar
Hi -
Doesn't your 2000 2.7 have a 5x100 bolt pattern? If so, how did you mount those rims (with a 5x115 mounting pattern) onto your car?
Shoman
Old Apr 3, 2006 | 03:45 AM
Cmoney's Avatar
Sorry, I screwed up. It does have the 5x112 pattern, not a 5X115. I had to get longer bolts and I had to keep tightening them every few days for about the first 1000 miles after I put the new wheels on. After that, they were good. Good Luck.
Old Apr 5, 2006 | 05:47 PM
A6Audi's Avatar
ORIGINAL: xcharrier
Isn't a 45 offset too much the best i think is 35
