windows that automatically roll up with remote.
RE: windows that automatically roll up with remote.
No, it is in St. Louis.. Sorry I guess i can't help you, If you plan on using a Vag a lot they are $200 off Ross-tech.com. This will let you change features, Check CEL codes and othergood stuff. Idk if you plan on using it alot its a good option.
Deffinatly, thats why i havnt bought one. If you ever get your hands on one and do the windows try doing the transmisson code too if you have a tip. You change the code from 00002 or 00102 to 00032 or 00132. this will allow you to hold first gear while in tip mode.
If you're just wanting to play around with the windows, read fault codes, reprogram the door locks, etc.the free (limited) version of VAG-COM works just fine with an ebay VAG cable for $10.
2nd that.
ORIGINAL: slee22
3rd that.
IMHO, if you're planning on doing any kind of real work on your ride, you almost *need* the vag-com. While I'm no pro mechanic, I do most of my own work, and without the vag, I would have pulled my hair out more than a few times. It's very, very well worth the 200 bucks, and it'll easily pay for itself the first time you get a wacky-*** CEL light that you can fix yourself for 5 bucks and 20 minutes worth of work (like a vacuum line that gets a hole in it).
#18
im thinking of picking up a cable on ebay... would this do tha trick?
http://cgi.ebay.com/ebaymotors/KKL-4...spagenameZWDVW
i already have the program so will it work with that cable?
#19
ORIGINAL: slee22
i can get the cable but where do i get the free limited vag-com software?????
#20
